July Products
EP Editorial Staff | July 14, 2011
0711mplace1SS Sanitary Check Valve
Check-All’s 3-A Sanitary Check Valve is an all-316/316L stainless steel unit with a standard 32 Ra or better finish, for use in new or existing sanitary systems. The 3SC design seals on the ID of sanitary ferrules with 3-A specified materials (standard is EPDM). This easily disassembled valve seals inside fittings such as Tri-Clover® Bevel Seat and Tri-Clamp®, Waukesha Cherry-Burrell’s   Q-Clamp® and S-Line® and others with ID dimensions equal to the “F” dimensions listed.
Check-All Valve Manufacturing Co.
West Des Moines, IA
0711mplace2Piezoelectric Accelerometers For Nuclear Environments
Meggitt’s Endevco® model 7703A series is a high-temperature, radia-tion-tested piezoelectric accelerometer family designed for general vibration measurements on structures and objects, including those in nuclear environments. Available in ranges of 50, 100, 200, 300 and 1000 pC/g, devices in the series feature a 10-32 side connector and highly stable shear mode construction, offering low base-strain sensitivity, high resonance frequency, insensitivity to thermal transients and excellent output stability over time. They’re ground-isolated to prevent EMI/ground loop interference and hermetically sealed to avoid external contamination.
Meggitt Sensing Systems
A Meggitt Group Division
San Juan Capistrano, CA
For more info, enter 31 at www.MT-freeinfo.com
0711mplace3Arc Flash Analytics
DC Arc Flash Analytic software from  ArcAd is intended for arc flash and shock-hazard analysis in DC power systems, including photovotaics, battery banks, rectifiers and telecommunications equipment. The program takes system voltage, available short-circuit current and other factors, then determines incident energy released by arc flash, hazard-risk category at working distance and flash-pro-tection boundary. It performs analyses using metric or imperial units, saves input configurations and calculations and generates customized warning labels.
ArcAd, Inc.
Etobicoke, ON, Canada
For more info, enter 32 at www.MT-freeinfo.com
0711mplace4Non-Electric, Liquid Drum Vacuum
Exair’s compressed air-powered Reversible Drum Vac™ offers an effective way to clean up liquids, including coolants, hydraulic oils, spills, sludge, tramp oil and wastewater. With no moving parts, it provides main-tenance-free operation. This system includes  a 110-gal. drum with bolt ring and lid, shut-off valve, drum dolly,  10’  vaccum hose,  ABS Spill Recovery Kit, aluminum wand, 11” and 24” crevice tools, skimmer tool, 20’ compressed air hose and tool holder.
Exair Corp.
Cincinnati, OH
For more info, enter 33 at www.MT-freeinfo.com
0711mplace5Problem-Solving Multimeter
Built to withstand harsh environments, Ideal Industries’ 490 Series Multimeter offers users a feature-rich tool with True RMS readings, Auto AC/DC voltage (1000V) and current mode with frequency indication, auto selection for resistance/continuity/diode/capacitance, plus data acquisition and logging of up to 20,000 records when used in unattended monitoring of signals over time. High Frequency Rejection (HFR) mode provides accurate voltage/frequency readings on non-sinusoidal waveforms, such as those in adjustable speed drives.
Ideal Industries, Inc.
Sycamore, IL
For more info, enter 34 at www.MT-freeinfo.com
Quick-Setup, Short-Term, Natural Gas Power Option
Aggreko’s 1300 kW natural gas generator provides a new rental option for users needing quick and effective short-term power generation. It incorporates the Cummins QSK60 gas engine, an emissions-control engine technology used within the temporary utility market. Turbocharging and low-temperature after-cooling ensures efficient performance. The product’s modular design, standardized in 20’ ISO containers, allows for easy transportation and flexible installation. Packaged control technology lets units be set up in parallel in minutes. On-board synchronizing gear automatically integrates into the grid, minimizing disruptions and fluctuations in power. These quiet, smokeless, “lean-burn,” units can be scaled up or down, allowing capacity to change with demand. EPA-compliant, they meet the most demanding U.S. emissions guidelines.
Aggreko
Houston, TX
For more info, enter 35 at www.MT-freeinfo.com
High-Temperature Accelerometer
IMI Sensors’ low-cost, high-temperature ICP® accelerometer model HT602D01 is intended for vibration measurements on paper machines and many other higher-temp applications. These ceramic shear units include a 2-Pin MIL-C-501 side-exit connector in a low-profile housing. Environments up to +325 F/+163 C can be tolerated. The sensing element provides a sensitivity of (±10%) 100 mV/g (10.2 mV/(m/s²) with a frequency range of (±3dB) 30 to 480000 cpm (0.5 to 8000 Hz).
IMI Sensors
A division of PCB Piezotronics
Depew, NY
For more info, enter 36 at www.MT-freeinfo.com
0711mplace6Attention-Grabbing, Cut-Resistant Safety Gloves
Youngstown Glove’s Titan XT™ lined with Kevlar® product is highly visible, cut-resistant and durable. Foam padding and TPR knuckles across the top of the hand protect users from smashing, pinching and cuts due to heavy machinery, power tools and broken glass. The company says the palms on these colorful products exceed Level 3 on the ANSI/ISEA 105-2005 Mechanical ratings for cut resistance.
Youngstown Glove Co.
Agoura Hills, CA
For more info, enter 37 at www.MT-freeinfo.com
