February
0212mplacefieldawareField-Service Software For Smartphones
 FieldAware’s cloud-based field-service management solution uses native apps on Apple and Android smartphones and tablets to eliminate the need for servers, proprietary software and special hand-held devices. By digitizing service workflow, it also eliminates the need for paper work orders and streamlines scheduling. Customer, product, task and work order data is shared over the Internet via Web-browsers or smartphones on a 24/7 basis. For a monthly per-user fee, FieldAware handles the entire service delivery process.
FieldAware
Frisco, TX
0212mplacegeneralRugged Video Inspection System
 The SEEKER 280 Ruggedized Video Inspection System (DCS280) from General Tools is designed for heavy industrial use. The unit comes standard with a 9mm-diameter, 1m-long, flexible-obedient probe that is water-, oil- and dust-proof to IP67 standards. The console with 2.4” color monitor meets IP54 standards for dust- and water-resistance. Applications include detecting leaks and cracks in ducts and piping and inspecting for corrosion and deposit buildup.
General Tools & Instruments
New York, NY
For more info, enter 32 at www.MT-freeinfo.com
0212mplacetestoHigh-Res Thermal Imaging
 Testo’s 890 Thermal Imager achieves high levels of image quality by combining 640 x 480 pixel detection, high-quality optics and the company’s SuperResolution technology. The unit records high-resolution thermal images in 1280 x 960 pixel quality, allowing small or distant objects to be inspected with precision. Other features include touch-screen navigation, a thermal sensitivity of <40 mK and temperature recognition up to 2192 F.
Testo USA, Inc.
Sparta, NJ
For more info, enter 33 at www.MT-freeinfo.com
0212mplaceturckFlow & Temperature Sensor
 Turck’s Digital Read Out (DRO) flow sensor is a self-contained, fully programmable sensor that allows for both flow and temperature monitoring, and features a three-digit display that can alternate between the two. The unit can be used in different media, such as water, glycol and Galden HT110, allows for application-specific set points and can track changes in flow from 0.2 to 12 gpm.
Turck, Inc.
Minneapolis, MN
For more info, enter 34 at www.MT-freeinfo.com
