The Corporate Report 2011: Des-Case Corporation
Des-Case understands the importance of fluid cleanliness and the role it plays in helping equipment investments last longer. For more than 25 years, we’ve pioneered solutions to help maintain lubricant quality specific to your applications. Featuring designs unparalleled in the marketplace, Des-Case products are used wherever lubricant life and performance are essential to daily operations.
Industry-Leading Manufacturer of Desiccant Breathers
- Continuous innovation. Des-Case invented the desiccant breather and continues to design new innovations.
- Widest variety of high-value solutions.From small gearboxes to large hydrau-lic systems or storage tanks, Des-Case breathers are engineered to last and matched with your specific needs.
A Full Line of Fluid-Handling Products & Adapters
- Easily customizable. Des-Case filtration systems can be easily configured to your exact needs. Larger systems are also designed to your specs.
- Rugged designs/thousands of options.Des-Case systems incorporate smart technology to make contaminant filtration a simple task, requiring less equipment and labor, while redu-cing system contamination.
Lubrication TransformationSM : Putting Best Practices Into Practice
Des-Case Lubrication TransformationSM Services help companies further develop world-class lubrication practices. Man-aged by experienced lubrication engineers, the Lubrication Transformation process can help you and your team implement best-in-class lubrication practices. Visit descase.com to learn more about the variety of plant-survey, design and training options available.
Whenever you’re in need of contamination control, rely on Des-Case to provide the right products to keep you up and running.
675 N. Main Street
Goodlettsville, TN 37072
Ph: 615.672.8800
www.des-case.com
