LMT Products Lubricants Lubrication Products
Royal Purple’s Synergy Gear Oil Provides Performance Under Extreme Pressure
Greg Pietras | February 14, 2014
Synergy extreme pressure (EP) gear oil from Royal Purple is engineered for service in high pressure pumping. It is designed to operate under the stresses that pumps experience when injecting drilling fluid into boreholes on drilling rigs. The lubricant provides protection under virtually all conditions found in pumping, including heavily loaded, slow speed operations and/or heavy shock load conditions. Synergy’s built-in solvency keeps gear boxes clean and extends oil drain intervals, decreasing the amount of oil needed as well as costs over the life of the pumping system. For more information, click here.
Royal Purple
Porter, TX
Greg Pietras
