OMEGA Introduces Wheatstone Bridge Universal In-Line Signal Conditioner
Jane Alexander | December 31, 2015
OMEGA (Stamford, CT) has introduced a Wheatstone Bridge universal in-line signal conditioner housed in a rugged stainless steel enclosure connected between the transducer and a readout instrument.
According to the company, this OMEGA IN-UVI product provides easy accessibility for transducer field calibrations, especially when space is limited, and is well suited for applications where a transducer must be located in a hostile environment or some distance away from the display.
(Note: If the environment at the sensing site is subject to high temperatures, humidity, or corrosive conditions, it may be necessary to place the in-line amplifier away from the transducer.)
How It Works
Supplying a highly regulated bridge excitation voltage for the transducer or load cell, the OMEGA IN-UVI offers a range of features and capabilities, including:
• improved signal to noise ratio
• two selectable excitation voltages
• wide zero adjustment range
• isolated shunt calibration relay for quick field setup.
All output options and excitation voltages for these devices are field selectable.
