November
EP Editorial Staff | November 1, 2009
1103mark1Laser Alignment For Steam And Gas Turbines
Centralign Ultra from Ludeca was developed for the alignment of steam and gas turbines.
The system precisely aligns internal elements with upper halves installed or off, for distances up to 133 ft. Accurate bore measurements can be acquired without interrupting other work taking place in the turbine, saving time over traditional methods. Centralign Ultra assures true bore center measurement and reveals bore out of roundness. Stable wireless data transmission ensures reliable and complete data transfer of information between the measuring sensors and the computer.
Ludeca, Inc.
Doral, FL
1103mark2Submersible Sewage Pumps With Premium-Efficiency Motors
ABS EffeX submersible sewage pumps are driven by premium-efficiency motors that reduce energy consumption and environmental impact. The pumps are designed to provide higher pump reliability, fewer blockages and lower operational costs for wastewater treatment facilities. They have been introduced in anticipation of forthcoming legislation in many countries regarding higher motor efficiency for submersible pumping. According to the company, the new pumps focus on delivering reliable operation, with greater safety margins and greater blockage resistance.
ABS Group
Meriden, CT
1103mark3Portable Calibration Verification
Wahl’s Heat Spy® Portable Calibration Black Body is  an ambient-temperature black body used for single-point calibration verification and the checking of  thermal imaging   cameras, as well as point IR thermometers. With an accuracy of ± .3 F (.2 C) over the entire range, it offers a reliable way to confirm instrument accuracy both in the field and in-house. Housed in a watertight IP67 carrying case, the Portable Calibration Black Body is lightweight, portable, and easy to use. Simply turn it on, point and compare readings.
Wahl Instruments, Inc.
Asheville, NC
1103mark4Pushbutton, Side-Entry Terminal Block
WAGO’s new 805 Series side-entry PCBs can simplify wiring via push-in and push-button-actuated  terminations. They come in standard 2- to 24-pole configurations; feature 3.5mm pin-spacing for conductors AWG 24–16; and are UL/CUL certified at 300V/10A. The 805 Series also offers the industry’s only internal factory-installed jumper system for commoning, conserving conductor capacity in high-density applications. According to the company, these products significantly reduce wiring times.
WAGO Corporation
Germantown, WI
1103mark5Electric Torque Multipliers
Mountz says its electric torque multipliers make for easy, precision tightening and loosening in heavy-duty fastening tasks. The product shuts off when pre-set torque is achieved, is non-impacting and operates at a smooth, continuous rotation with a high-performance, brushless motor. These tools eliminate the cumbersome setup time and slow ratcheting process of hydraulic wrenches. Mountz also says using its product is ergonomically safer than hammering with an impact wrench.
Mountz, Inc.
San Jose, CA
1103mark6Control-Switch Relay Mitigates Arc Flash
A Time Delay Control Switch Relay (TD-CSR) from Electroswitch provides a safe and effective means for local control to mitigate the arc flash danger in circuit breaker operation. It allows for a manually initiated time-delay trip or close operation that incorporates a flashing LED to notify the operator of a pending trip or close operation and to evacuate the “arc flash” area. SCADA operation is not required. Local trip or close capability is initiated and delayed for 10 seconds with an option to easily cancel the pending trip or close operation.
Electroswitch Corporation
Weymouth, MA
Ultra-Low-Noise Remote Charge Converter
The model 2771C-XX ultra-low noise remote charge converter (RCC) from Endevco Corp. is for use with charge output piezoelectric sensors within mechanical-system health monitoring, nuclear power plant/regenerative energy and environmental testing applications. Model 2771C-XX offers a rugged two-wire (IEPE), single-ended design that operates from constant current power (4-20 mA). Both RCC signal output and current to the RCC are carried along the same wire. The converter offers broadband noise range down to 5µ Vrms, with a frequency response of 0.4 to 50 kHz.
Endevco Corp.
San Juan Capistrano, CA
For more info, enter 43 at www.MT-freeinfo.com
Structured Bus Solution
The Powerwave Bus System ™ from PDI is a modular pre-engineered product line expansion into the structured bus distribution market. PDI has incorporated the simplicity of vertical drop downs from a common bus with the integration of PDI’s award-winning Wavestar™ technology for intelligent monitoring and communications. The system features a 225 and 400 amp continuous rail system; Tough Rail Technology™ that streamlines and simplifies installation; Integrated Wavestar™ communications bus; and a wraparound electromagnetic interference (EMI) shield.
Power Distribution, Inc.
Richmond, VA
For more info, enter 44 at www.MT-freeinfo.com
Video Software Supports Wonderware ActiveFactory
Video Historian software from Longwatch that supports the Wonderware ActiveFactory trend chart object enables users to link plant video directly with Wonderware’s graphical data trend charts automatically. The result is the ability to see exactly what was happening in the plant when trend pens were in a particular condition. This application is part of the Longwatch Version 5.0 system.
Longwatch, Inc.
Norwood, MA
For more info, enter 45 at www.MT-freeinfo.com
