EP Editorial Staff | April 18, 2011
Lightweight, Portable Tachometer
Ono Sokki’s HT-4200 tachometer weighs less than 4.5 oz. Measurement setup is as simple as applying a small piece of reflective tape marker or reflective paint to the target surface. The device’s light beam has a 12” range, allowing measurements up to 50,000 rpm to be taken quickly and with an accuracy of 1 rpm.
Ono Sokki Technology, Inc.
Addison, IL
Intuitive Vane Anemometer Pens
Control Co. offers Traceable® Vane Anemometer Pens that measure combinations of air-flow, temperature, humidity, dew point and barometric pressure. The design allows for intuitive, easy operation, while a tough ABS plastic housing with an O-ring seal and membrane keypad keep out dust and dirt. Min./max. readings can be recalled; a hold button can freeze a current reading.
Control Co.
Friendswood, TX
Portable, Four-Channel Oscilloscopes
Fluke ScopeMeter® 190 Series II four-channel handheld oscilloscopes are engineered to reduce user exposure to electrical shock. Dust- and drip-proof rated, they’re also safety-rated for CAT III 1000 V / CAT IV 600 V environments. The series is offered in 100MHz and 200MHz bandwidth models, with real-time sampling rates up to 2.5 GS/s and 400 ps resolution to capture noise and other disturbances.
Fluke Corp.
Everett, WA
Universal Locking Device
The NL-H Hybrid Lock from Netherlocks can provide secure lockout for all types and sizes of manual valves, and can secure valves in every position. Its universal compatibility eliminates the need for other lockout products. The lock uses a flexible steel cable to immobilize a valve’s handwheel or lever and secures with a padlock. It is made from corrosion-resistant 316 stainless steel for harsh-environment operation.
Netherlocks Safety Systems
A Halma Company
Houston, TX
Stainless-Steel Grounding Station
The Cen-Stat™ Grounding Station from Newson Gale provides an extra margin of safety when operations in flammable or explosive atmospheres make static electricity a significant hazard. Constructed of stainless steel, this product is designed to accommodate two general-purpose grounding clamps and provide for clamp stowage. Two or more stations can be linked, using the same proven path to ground.
Newson Gale, Inc.
Jackson, NJ
Easy-Maintenance Diesel Generator
Next Generation Power’s EPA-compliant UCI 2-5.5 kW Diesel Generator is a versatile solution for back-up and auxiliary power. At 240 pounds and 23” long, 20” wide and 21” tall, it fits onto trailer tongues and into tight spaces for mobile or stationary applications. A low 2800-RPM operating speed minimizes wear and vibration, while one-side service enables easy maintenance.
Jacksonville, FL
