LMT Products Lubrication Products
Des-Case Introduces Extended Series Desiccant Breathers
EP Editorial Staff | May 14, 2014
051414descaseThe Extended Series from Des-Case are high airflow, long-lasting desiccant breathers with check-valve technology suited for tank farms and large applications. Umbrella check-valves are located underneath the unit for added protection from washdown environments, while an integrated standpipe provides vibration resistance and dissipates impact throughout the unit. Des-Case’s Honeycomb Technology Oil Mist Reducer is situated inside the standpipe, and is made from polypropylene for maximum chemical compatibility. This feature allows oil mist to coalesce and drain back into the reservoir, rather than compromising the desiccant. Other features include 1.2-4.2 lbs of Desiccant and higher airflow (24-27cfm). Click here for more information.
Des-Case Corp.
Goodlettsville, TN
