Kaeser Compressors Introduces Two Variable Speed Rotary Screw Compressors
EP Editorial Staff | May 7, 2014
Kaeser Compressors announces availability of its new SFC 18S and SFC 22S variable speed belt-drive rotary screw compressors designed for reliability, simple maintenance and sustainable energy savings. The SFC 18S has a flow range of 33-119 cfm (0.93-3.37 cmm) at 125 psig (8.6 bar) and is available with pressures up to 217 psig (14.9 bar). The SFC 22S has a flow range of 33-141 cfm (0.93-3.99 cmm) at 125 psig, with pressures up to 217 psig. Both models feature the latest in Siemens drive technology. Enhanced cooling enables applications in severe operating conditions. These units feature a new air end designed to optimize performance and efficiency and TEFC premium efficiency motors are standard. Kaeser claims energy efficiency improvements up to 20% compared to competitive compressors. Compact design and two large hinged service doors make it possible to service the unit from one side. An automatic belt tensioning device prolongs belt life and simplifies service, while maintaining optimal drive efficiency. The SFC 18S and 22S are also available with an integrated compressed air dryer. More information is available here.
Kaeser Compressors, Inc.
Fredericksburg, VA
