Automation Products Sensors
IMI Sensors Launches ICP Accelerometer with Integral Magnet
Melissa Larson | August 4, 2015
IMI Sensors, manufacturer of industrial vibration monitoring instrumentation, announced the release of Model 607M123/YYYCC, a high-frequency ICP accelerometer with integral magnet and integral cable to be used in route-based measurements.
Unit is a configurable model with choice of cable length and connector type. The model has a sensitivity of 100 mV/g, a ±50g peak measurement range and a frequency range (±3 dB) of 0.5 to 13,000 Hz. The model is housed in a welded-hermetic stainless steel housing with an integral over-braided polyurethane cable and integral flat rare-earth magnet. The key feature is the inclusion of both a configurable integral armored cable and integral flat rare-earth magnet, which allows for efficient attach/disconnect of sensor. This quicker connect/disconnect mechanism can save considerable manpower over stud mounting in route-based predictive maintenance.
Melissa Larson
