Actuated Diaphragm Metering Pump
Gary Parr | July 12, 2016
Series MP7100 mechanically actuated diaphragm metering pump incorporates the ruggedness of a hydraulic diaphragm metering pump, eliminates the need for intermediate fluid or hydraulic oil to actuate the diaphragm, and reduces the potential for gearbox oil to contaminate the process. The result is a pump design said to provide reliable and accurate dosing of a wide range of mild to aggressive chemicals, including those used in municipal water and wastewater treatment. The pump has a maximum capacity range to 275 gph, pressures to 235 psi, and a suction-lift exceeding 20 ft. on water-like chemicals.
Neptune Chemical Pump Co.
North Wales, PA
neptune1.com
