Lithium Grease
Gary Parr | July 7, 2016
CorrLube VpCI EP grease is lithium complex grease formulated with premium quality, severely hydro treated base stock. Said to provide excellent resistance to oxidation and with high temperature stability, it is suitable for operating and lay-up conditions. The formula is designed with properties that protect against salt water, brine, H2S, HC1, and other corrosive agents. It also incorporates Vapor phase Corrosion Inhibitors (VpCI) for areas not in direct contact with the grease. The grease remains effective in extreme operating conditions such as high temperature, high pressure, and shock loading, and aids in the suspension of solid additives such as graphite, molybdenum, and disulfide. Thicker film consistency allows it to operate on worn parts.
Cortec Corp.
St. Paul, MN
cortecvci.com
