Internal-Mix Spray Nozzles
EP Editorial Staff | August 27, 2019
The 1/8 NPT small internal-mix spray nozzles atomize fluids at a rate of 42 gal./hr.
The nozzles mix the liquid and air inside the cap, produce fine atomization, and can be used on liquids with a viscosity to 300 centipoise. The products are available in narrow-angle round pattern, wide-angle round pattern, and flat-fan pattern and combine liquid and compressed air to create a coating that can be adjusted for a range of applications.
EXAIR Corp.
Cincinnati
exair.com
