Enhanced Ground Tester
EP Editorial Staff | October 17, 2019
The DET2/3 earth/ground resistance tester includes an optional test lead reel that is said to dramatically reduce time and frustration for the operator.
Designed to test communications and ground systems, the tester has a graphic display for better data analysis, excellent error detection capabilities, and a range of test frequencies to ensure noise protection.
With a test frequency range of 10 Hz to 200 Hz in steps of 0.5 Hz, with an automatic frequency selection feature, it allows users to ensure tests are carried out at the frequency with the lowest noise level. The unit includes a large internal memory that allows immediate calculation of resistivity and can store more than a day’s worth of test results. The results can be downloaded to a USB flash drive or directly to a PC running PowerDB software.
Megger
Norristown, PA
us.megger.com
