Products
Pulse valve
EP Editorial Staff | March 13, 2020
The ASCO Series 353 pulse valve has a higher peak pressure, wider temperature range, patented quick-mount clamp connection, and overall part simplification in its redesigned format.
The valve can be used in a wide range of applications, including concrete processing, grain, agriculture and feed, metalworking (abrasive blasting), food processing, foundries, pharmaceutical, mining, rubber mixing/processing, metal processing, lime industry, cement factories, power plants, and steel mills. Because it hits peak pressure quickly, the unit reportedly creates a more effective cleaning process.
Emerson
St. Louis
emerson.com
