Sanitary-Application Chains
EP Editorial Staff | March 13, 2020
Renold Syno chain line is designed for sanitary applications or when contamination from lube must not occur.
With no additional lubrication, Syno small and large pitch, are food-industry approved and dry to the touch. Small pitch has lubricant impregnated within the sintered bushing while the large pitch is composed of a specifically designed polymer sleeve between the pin and bushing. The full range is corrosion-resistant and said to withstand fatigue and wear. The products are available in boxed 10-ft. lengths, single and double pitch, and interchangeable with standard sprockets.
Motion Industries
Birmingham, AL
motionindustries.com
