Electromagnetic flowmeter
EP Editorial Staff | May 16, 2020
Proline Promag W electromagnetic flowmeter has no measuring-tube restriction, reportedly resulting in reliable measurements independent of the flow profile and the mounting location.
The flowmeter’s “0 x DN full bore” option is a solution for a close-knit pipeline network or obstacles in pipes. Promag W 300/400/500 flowmeters with the “0 x DN full bore” option measure with high accuracy (±0.5%), even directly downstream of pipe bends, T fittings, or insertion devices. They are particularly suitable for installation in tight spaces, such as compact systems or skids, because they do not need any inlet or outlet runs. The Promag W (0 x DN full bore) can easily handle swirls that frequently occur downstream of obstacles such as pipe bends and insertion devices, and even those downstream of unknown obstacles such as build-up on the pipe wall, protruding seals, or different inside diameters.
Endress+Hauser
Greenwood, IN
us.endress.com
