The Reliability Files
EP Editorial Staff | April 18, 2011
The issue’s edition of The Reliability Files includes information from Littelfuse and Inpro/Seal.
7+ Years And Counting: A Case Study Of Sealing Success
Problem
A nationally known gypsum company was experi-encing sealing problems with its product-mixing machines. It contacted Inpro/Seal® for help.
The plant turns out a range of gypsum-board and interior-finish product, including joint-treatment compounds, tape and plaster. Two large, twin-shaft mixers are used in the process—one for dry bagging compounds and the other for compounds used for ready-mix products. Located high, near the top of the building, these machines operate five days a week, intermittently because of the batch-style process.
With the standard sealing configuration, dry-powdered product was leaking around the shaft penetrations in the mixer. Facility engineering personnel attempted to implement other sealing solutions, including packing and a competitive product seal, both of which required substantial maintenance to be successful. Due to less- than-optimal attention to required maintenance, however, both options failed to keep the gypsum contained within the mixer, leading to several problems.
While gypsum may be a fine powder, it’s also abrasive. When packing was used to seal the mixer, the gypsum would frequently get caught between it and the shaft—eventually resulting in scoring of the shaft.
Product that escaped from the mixers was considered contaminated and had to be scrapped. In fact, the facility estimated it was racking up $5000 to $10,000 each week just in lost product. In addition, the product that was being released into the atmosphere was creating significant environmental and housekeeping concerns.
In one case, the powder migrated into the electronic process controllers and caused over $400,000 in equipment failures—and that didn’t include the cost of lost production.
Solution
Working with their local Inpro/Seal regional sales manager, the plant’s reliability engineers decided to install Inpro/Seal Air Mizers® on each mixing machine. (In total, they utilized eight Air Mizers to fully seal the two twin-shaft mixers.)
The Air Mizer is a non-contacting product seal that uses small amounts of air to create a positive purge along the rotating shaft—sealing product in the equipment and keeping contaminants out. It fully articulates to accommodate radial and angular shaft movement and shaft run-out.
For this application, the Air Mizer was designed to use 4-6 SCFM of air at an operating pressure of approximately 3 psi above the maximum mixer pressure. The application also required split seals that could be easily installed (without having to dismantle the mixers).
Return On Investment
The gypsum mixers have been operating since August 2003—without the need for maintenance or replacement parts. The facility’s operators have been pleased with the performance of the Air Mizers and the significant return on their investment. They’ve also expressed overall satisfaction with the technical support they received from the Inpro/Seal team. They no longer worry about product loss, damage to plant equipment or environmental hazards within their facility due to leaking seals. MT
Inpro/Seal
Rock Island, IL
Solve The #1 Motor-Failure Problem With Accurate Temperature Detection
Problem
A thermal-based motor overload relay may allow a restart on a hot motor prematurely because a bimetallic overload relay cools faster than the motor it is protecting. Once the relay resets, an operator can restart the motor, potentially causing costly equipment damage. The National Electrical Manufacturers Association (NEMA) reports that for every 8-10 degrees a motor is operated above its manufacturer’s recommended maximum operating temperature, motor life is cut by half. To preserve the investment in a motor and avoid downtime and replacement labor, an accurate measurement of motor temperature is essential.
The elements of a traditional bimetallic overload clearly have less mass than a motor and can be expected to cool faster. Manufacturers take this into account when designing these devices, which generally do a reasonably good job of emulating the condition of the motor (assuming they are installed in the same ambient temperature environment as the motor). However, the sensitivity of the traditional overload device cannot adjust dynamically to respond to overloads and time; consequently, it cannot provide an accurate temperature model in all situations. Also, each time a bimetallic overload trips, its setpoint shifts slightly. After a number of trips, it will drift out of calibration.
Solution
Electronic motor protection relays that use dynamic thermal modeling (Fig. 1) to accurately predict motor temperature are available. By tracking the motor current and the amount of thermal capacity used (I2t), an electronic relay can accurately calculate the temperature of the motor under all operating conditions. The relay also looks at the input of the temperature sensors in case there is a heat problem unrelated to current, such as high ambient temperature or blocked motor ventilation. This approach has proven to be more reliable than depending on the input of winding temperature sensors alone.
The Littelfuse PGR-6150 Motor Protection Relay has sophisticated thermal modeling that can accurately protect the motor from overheating, monitor trends in motor conditions to provide a warning before damage occurs and notify the operator when it is safe to restart the motor.
This relay also detects many other problems, such as jams, phase unbalance and overloads, and displays alarms that aid in troubleshooting. Other motor protection relays, such as the Littelfuse PGR-6100, detect ground faults and monitor motor-winding resistance for worn or melted insulation. If the windings are damaged, this kind of relay keeps a motor from starting, thus preventing damage to the unit. It can also reduce the risk of electrical shock and arc flash, because the windings are prevented from degrading and causing a short circuit condition.
NEMA identifies overheating as the leading cause of motor failure. It is not uncommon for operators to restart a hot motor without understanding and correcting the cause of an overload condition, leading to additional heat and damage. Fortunately, modern protection relays can assist with troubleshooting and prevent motor damage.
Electronic relays are easy to justify, and many maintenance managers see the value of upgrading their old-fashioned thermal overloads. The cost of electronic motor protection relays has decreased, and at the same time their features have increased, making them more attractive for protection of smaller, lower-horsepower units.
For more information on motor protection relays, please visit www.littelfuse.com/protectionrelays.
Littelfuse
Chicago, IL
