Maintenance News Products
Milwaukee Tool Offers Tough M12 7.8KP Thermal Imager with DUAL SENSE Pixels
Jane Alexander | December 28, 2015
Brookfield, WI-based Milwaukee Tool (“Milwaukee”) has added the M12 7.8KP Thermal Imager to its M12 portfolio of tough, professional-grade power tools.
According Milwaukee, this product features the highest pixel density in its class, along with new DUAL SENSE pixel technology for what the company said is “superior definition of hot and cold details within the same image.”
How It Works
• The manufacturer’s exclusive DUAL SENSE technology allows the 7.8KP to individually optimize pixels to eliminate the blurring of hot and cold details in complex scenes. Equipped with 83:1 distance-to-spot performance, dual lasers, and hot/cold spot locators, the unit lets users to quickly scan, target, and capture temperature readings from long range or small areas.
• As a complete problem-solving solution, the M12 7.8KP is fully compatible with the company’s powerful Thermal Imager Report Software. Available online, this software simplifies and speeds image analysis and report generation. Users can quickly download images from the device with the included 8GB SD card or Micro-USB connection port. Every image capture creates a versatile .PNG file format image that can be shared with others.
• For added protection in the field, Milwaukee has designed the entire the  M12 7.8KP unit to withstand a 6-ft drop. The imager also comes with a protective cover that wraps around the LCD screen and front sensor to help the device perform amid the toughest of jobsite conditions.
• Powered by REDLITHIUM battery technology, the 7.8KP leverages the  M12 battery system’s runtime and straightforward field replacement to eliminate downtime. Use of the M12 battery makes this thermal imager compatible with Milwaukee’s entire M12 System of power tools.
Jane Alexander
