Additions to Valve Line
Gary Parr | January 19, 2017
The Nitra pneumatics solenoid valve line includes two additional series of valves and manifolds. The BVS-3 series modular solenoid valves are body ported 3-port (3-way) poppet valves available in two-position, normally open or normally closed configurations, with 12- or 24-VDC or 120-VAC coils. The BVS-4 series is two-position, single-spring return, body-ported 4-port spool valves. With 1/4-in. push-to-connect ports and 12- or 24-VDC and 24- or 120-VAC solenoid coils, the valves have removable flying leads or an 8-mm micro-DIN connector.
AutomationDirect
Cumming, GA
automationdirect.com
