Rectangular Photoelectric Sensors
EP Editorial Staff | May 1, 2020
Wenglor rectangular 50 x 50 x 20-mm photoelectric sensors include diffuse with background suppression, retroreflective, retroreflective for transparent objects, and through-beam models.
Sensing ranges vary from 1,200 mm for background-suppression sensors to 20 m for through-beam models. With the standard 50-mm x 50-mm housings, the sensors provide long range and small spot diameter, simple potentiometer sensitivity adjustment, visible red-light emission for easy targeting set-up, and are compatible with the IO-Link open-standard protocol. Outputs are LO/DO (light-on/dark-on) non-equivalent (antivalent) complementary NO/NC. Right-angle fixed and swivel mounting brackets are available for flexible mounting options. The swivel mounting brackets allow 360-deg. vertical and horizontal adjustment.
AutomationDirect
Cumming, GA
automationdirect.com
