Products
Larson Electronics Introduces Hazardous Location LED Light Fixture
Melissa Larson | September 17, 2015
Larson Electronics announces the release of a magnetically mounted Class 1 Division 2 hazardous location LED light fixture designed for use as a temporary lighting solution for those applications that do not require permanently mounted fixtures.
The light fixture is equipped with four 200 pound grip magnets and provides daisy chain capabilities to allow end-to-end connectivity throughout the workspace. This Class 1 Division 2 rated fixture is constructed of non-corrosive materials including a polyester housing reinforced with glass fiber, a poured in gasket for reliable sealing and an impact resistant acrylic diffuser.
Eight corrosion resistant plastic latches secure the lamp cover to the housing and provide a firm lock against the poured in seal to prevent drips and water intrusion. This 4 ft. long, two-lamp magnetic mount LED light fixture is ideal for operators seeking a top quality hazardous location light that will reduce operating costs, improve light quality, and reduce downtime incurred from frequent servicing intervals. This fixture comes standard with two 28 watt LED lamps that are LEL listed, providing 125 lumens/watt for a total of 3,500 lumens/lamp. These lamps produce 30% more illumination than standard T8 bulbs, offering lower amp draw and increased reliability while providing 50,000 hours of service life.
Melissa Larson
